power on
6 TopicsPoE doesn't start_GS308EP
We use the GS308EP to manage 2 differents VLAN in our custom system. the port 1 is used to power on a RFID reader (FEIG MR102), the others ports are for classic ethernet commnication. We configure it as we wanted and it works as expected, but we have an issue on the activation of the PoE function at the start of our system. The switch power supply come from an electric inverter (which supplies the main power line when its function of inverter is not needed). Upstream the inverter we put a circuit breaker (2CSR275180R1164 DS201 M C16 A30). Our issue follow this patern: If we turn our system ON, by starting it from the inverter (with the circuit breaker open), the PoE launches without a problem, in all cases. If we turn our system ON, with the circuit breaker close and we start the inverter, the PoE doesn't launch, and if we open the circuit breaker, the supply from the inverter takes over and the PoE launches immediatly When we say "PoE doesn't launch", we mean the green led on the port (and the orange) doesn't turn ON. And we say that "the PoE starts" because the green led turn ON. We suspected the circuit breaker, and change the type (from AC to A), but the issue continue. We have isolated the switch to keep only the port 1 (to know if the issue could came from some interference from something else), but the issue still occur. What is bother us the most is that, after changing the circuit breaker, the issue seemed to have been resolved (we made severals power ON test), and the PoE did activate in some previous problematics cases, but at one time, on another test of power ON, the PoE didn't launch (only by open the circuit breaker like before), and we went further by powering it ON on a normal power outlet , and even like this, the PoE didn't launch... The software is up to date (V2.0. something), the configuration seems ok, we activated the long time detection, etc It is not an isolated case, on one of our other product we reproduce the issue (same hardware configuration). Thanks for the help we could get.N600 Router Model C3700 - Power on, All Lights Flash Periodically, No Internet, No WiFi
C3700|N600 Cable modem wifi router. 1.y years old. It suddenly stopped working. When switched on power light is getting on (green) and nothing happens then after a while (may be 30 secs) all the lights flash and goes off then power stays on. The router stays on like this (periodic flashing of all the lights). In this state the router is not accessible with either by network cable nor by WiFi and there is no internet connectivity as well. This problem was occuring once in a while and then it got resolved automatically i.e. if you switch it off and leave it like that for hours and switch it on then some time it worked earlies. But now it stopped working completely and it exhibits the above mentioend behavior consistently and not going back to the working state. Whether it indicates the firmware got corrupted and it need to be reinstalled. If yes how to do that? Factory reset and power cycle did not help. The behavior remains the same (i.e. power on, periodic flashing of all the lights but no internet, no WiFi and no connectivity to the modem/router).6.7KViews0likes1CommentAircard 785s won't turn on
4 months old aircard 785s will not turn on , will not charge or connect with PC via USB . there is nothing wrong with the lead or the charger. Currently trying to get phone support to return under warranty , by the time you lot get round to answering the phone it will have been cheaper for me to have just gone out and buy another!Solved6.4.1 RC1 wants to wake
This firmware wakes my 102 after it powers down. It's set to power down at 11 PM, which it does but immediately powers up again. This repeats at midnight but stays awake for 18 mins. After that if stays off until 6AM when it powers up as it should. The only 'activity' that happens in these unwanted periods of power on is AV updates.2.8KViews0likes6Comments6.4.0 102 - No scheduled power on.
My 102 powers down and up on a schedule, this has been the case without issue for a long time. Since upgradig to 6.4.0 (from 6.2.5) it no longer comes up correctly. I find the power light flashing and the NAS is uncontactable. If I pull the power and then reapply power and press the power on button the NAS comes up OK. Thus has happened every morning since the upgrade. The upgrade itself seemed to go OK ad the NAS came up OK after the upgade reboot. As far as I can see nothingis written to any logs at the failed auto power ons. Suggestions?3.2KViews0likes7Comments
