Squirt's avatar
Squirt
Aircard 785s won't turn on
4 months old aircard 785s will not turn on , will not charge or connect with PC via USB .
there is nothing wrong with the lead or the charger.
Currently trying to get phone support to return under warranty , by the time you lot get round to answering the phone it will have been cheaper for me to have just gone out and buy another!
  • Hello Squirt
    I have sent you a Private message about your case.
    DarrneM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Squirt
    DarrneM
    • dim-'s avatar
      dim-
      Hello, I have a similar problem. I can turn the device on, but the battery won't charge neither from the wall socket nor from the computer. How to solve this problem?
      • Squirt's avatar
        Squirt
        WIll yours turn on with the device plugged in to the mains, with the battery removed?
        Sounds like you have a duff battery.
  • Hello I have a same problem in device 785s.could you please help me to resolve this issue.
    • DarrenM's avatar
      DarrenM
      Hello Lalu227
      Have you tried to pull the battery and plug it in and power it on?
      DarrenM
