rbe970 series
4 TopicsNew - RBE970 Series v12.1.11.10 Firmware Release - WW Region
Release Date: July 28, 2026 Enhancements: Fixed an IGMP snooping issue that caused satellite connectivity failures, and multi-device connectivity problems. Fixed unknown reboot issue Enhance IPv6 connectivity Known issues: The Speed Test feature always displays a ping value of 0 ms instead of the actual measured latency. A firmware update to resolve this issue is planned for an upcoming release. Download Link: https://www.netgear.com/support/product/rbe972s NOTE: This is a major version update from v9 to v12. Firmware cannot be downgraded from v12 back to v9. If users are having problems after v12 has been applied, and have exhausted all troubleshooting in support forums, please make contact with NG support for continued help and information. Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE971.aspx#docs I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR971/RBS970: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: Orbi Systems Manual Factory Reset Process | NETGEAR Communities This sends a Factory Reset command to any and all connected RBS as well. Quick Installation Guide, User Manual and Spec Sheet is here: https://www.netgear.com/support/product/rbe971#docs This article applies to: Orbi (8) RBE970 RBE970B RBE971 RBE971B RBE972S RBE972SB RBE973S RBE973SB Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities Thank you.48Views0likes0CommentsNew - RBE970 / RBE971 Firmware Version 9.13.1.2 Released
Bug Fixes: 6/24/2024 Resolved voice and video drop issues Strengthened security protocols for guest network access to enhance overall network protection. Enhanced WAN failover and recovery mechanisms to improve connection reliability and stability. Addressed issues affecting the stability of 240 MHz band to ensure more consistent wireless performance. Optimized handling of wireless network configuration changes for smoother transitions and improved connectivity. Improved memory management on satellite devices to enhance performance and resource efficiency. Enhanced performance and stability of local device-to-device streaming. Extended multicast capabilities to improve efficiency and compatibility across connected devices. Improved APS functionality to ensure alignment with the latest regulatory requirements. Resolved graphical user interface (GUI) display issues for improved user experience and clarity. Download Link: https://www.netgear.com/support/product/rbe972s#download Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE971.aspx#docs IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR971/RBS970: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: Orbi Systems Manual Factory Reset Process | NETGEAR Communities This sends a Factory Reset command to any and all connected RBS as well. Quick Installation Guide, User Manual and Spec Sheet is here: https://www.netgear.com/support/product/rbe971#docs This article applies to: Orbi (8) RBE970 RBE970B RBE971 RBE971B RBE972S RBE972SB RBE973S RBE973SB Let us know how it works for you...815Views2likes0CommentsNew - RBE970 / RBE971 Firmware Version 9.13.2.1 Released
Release Date: NG Confirmed FW version. October 31, 2025 Bug Fixes: Resolved voice and video drop issues Optimized the Clear Channel Assessment (CCA) threshold for the 2.4GHz band to improve wireless stability and reduce interference in congested environments. Improved MLO roaming behavior to address connection issues when switching between router and satellites. Fixed issue where sorting options were missing under Advanced → LAN → Address Reservation Fixed authentication bypass vulnerability that allowed unauthorized password modification and admin access. Fixed security issues Download Link: Updated 11/2/2025 https://www.netgear.com/support/product/rbe972s Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE971.aspx#docs IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR971/RBS970: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: Orbi Systems Manual Factory Reset Process | NETGEAR Communities This sends a Factory Reset command to any and all connected RBS as well. Quick Installation Guide, User Manual and Spec Sheet is here: https://www.netgear.com/support/product/rbe971#docs This article applies to: Orbi (8) RBE970 RBE970B RBE971 RBE971B RBE972S RBE972SB RBE973S RBE973SB Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities Thank you.1.2KViews0likes0CommentsNew - RBE970 Series v12.1.10.12 Firmware - NA Region Only
Released: June 23, 2026 Bug Fixes: improves system stability. improves Wi-Fi client connectivity. improves mesh satellite connectivity and stability. New Feature - Protection Engine - https://community.netgear.com/discussions/en-home-routers-nighthawk-wifi-ax6/netgear-nighthawk---protection-engine-feature-faq/2407634 Known Issues: IPv6 is still under review. If IPv6 is not working correctly, please disable it on the RBRs web page. This is coming down Over The Air via Auto Update first to those who have auto update enabled or see this on the RBRs web page or Orbi app.. Download Link: https://www.netgear.com/support/product/rbe972s NOTE: This is a major version update from v9 to v12. Firmware cannot be downgraded from v12 back to v9. If users are having problems after v12 has been applied, and have exhausted all troubleshooting in support forums, please make contact with NG support for continued help and information. Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE971.aspx#docs I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR971/RBS970: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: Orbi Systems Manual Factory Reset Process | NETGEAR Communities This sends a Factory Reset command to any and all connected RBS as well. Quick Installation Guide, User Manual and Spec Sheet is here: https://www.netgear.com/support/product/rbe971#docs This article applies to: Orbi (8) RBE970 RBE970B RBE971 RBE971B RBE972S RBE972SB RBE973S RBE973SB Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities Thank you.621Views0likes0Comments
