readynas remote
6 TopicsReadynas RND2000 - Remote shows device offline even though it is connected and working
I have been using my Netgear Readynas RND2000 for a number of years and did have readynas remote connected and all was going well. Yes I did have to update the images and software versions to get it to connect remotely but it was working like a charm. This week, I replaced both the hard drives since there were increasing sector errors. The replacement went smoothly but the replacement seemed to reset all the settings / versions and images on the NAS to the original factory settings. I've entered the settings as I recall them being set at prior to the drive replacement and can use the NAS locally like a treat.... BUT I cannot access the NAS remotely using Readynas Remote any longer. I am able to log into Readynas remote and see the device but it shows as offline and will not connect. Can anyone help with some tips, advice, ideas..... I've read through so much on the forum and cannot find a solution. Help ! My system info ============ I am not sure if my RND2000 is version 1 or 2 but suspect possibly v1 as my serial number starts with 1VB3 (?) The local computer is Windows 7 - all other remote computers are Windows 10. I am running Radiator 4.1.16 Readynas Remote image version 1.0.9.78 (perhaps there is a newer version but this is the one I've installed after changing the drives ?) The Readynas desktop version is 1.7.6.28 PS I can also see the name of a device as it was set a few years ago (separate issue but does anyone know how to remove the NAS name from the list)3.9KViews0likes12CommentsReadyNAS Remote not available
Hi All, According to the below article, I should find "ReadyNAS Remote" under my browser menu. I can't find it. Is this a discontinued option or is there something I need to do to make that button available? http://kb.netgear.com/app/answers/detail/a_id/23837/~/how-do-i-enable-readynas-replicate-on-my-readynas-os-6-storage-system%3F?cid=wmt_netgear_organicSolved3.1KViews0likes1CommentCannot install ReadyNAS remote -dowloaded version May1- on Win10 : can't write ...npf.sys
I've downloaded ReadyNAS remote for windows today, via the instruction link in http://kb.netgear.com/app/answers/detail/a_id/20928 However, at almost the very start it fails on a certain driver. I disabled my Norton360 premier security just in case that blocked it. I've kept all the default prompted locations of the installation wizard. What's wrong? I've checked another thread on the forum that looked similar, but that did not help. My ReadyNAS duo is visible, accessable via RAIDar. I have installed ReadyNAS remote server version 1.0.9.78 on my ReadyNAS duo and invited myself over 2 different email address... that seems to end up in a ReadyCLOUD subscriptionSolvedreadynas remote legacy users affected by cloud outage?
I am still unable to connect to my readynas nv+ using readynas remote since the cloud outage. I notice there was a firmware update for readycloud users. is there going to be something equivalent for legacy remote users? any update would be appreciated. regards, Stephen Targett unit a architecture inc. toronto3.5KViews0likes7Comments
