remote management
2 Topics"Does not support Remote Access"
I have enabled remote management on the router (C7000-100NAS): Https, port 8443 But on the android genie app I get a "Does not support Remote Access" when I attempt to enable remote access on my Motorola E4. Is this a limitation of the phone? Or is there some other setting I need to enable on the router for this to work? Thanks, Biz2.5KViews0likes3CommentsRemote Management
I live abroad and before I left the USA, I turned on remote management on my R6900. I wrote down the Remote Management Address and allowed access by Everyone. I noted the port number too. I also signed up for another noip address/username so I can see and up to date ip address (at least I hope it worked and is updating the current ip address). While I am in Thailand, I tried to access my router with the https://XX.XXX.XX.XX:8443 but I get the return message site can't be reached, site took too long to respond. I checked with noip hostname & target ip, but still can't connect. Any ideas? Thank you.Solved19KViews0likes13Comments
