static route
2 TopicsStatic routing c6250
I have a c6250 and need to use a static route. As this is a router I know this is a capability ( basic capability in every OS and router OS ) but it does not seem to be exposed in the GUI for the product. Does anyone know how to add a static route on this router?1.5KViews0likes3CommentsCan not create a static route to single IP (Orbi 2.0.0.74)
When adding a static route to a single IP it is not applied. I'm trying to block access to certain IP's by adding static routes and directing them to the local interface on the Orbi. I enter the IP, Subnet 255.255.255.255, Gateway 10.0.0.1 and Metric 2. I press apply but it does not. Does not show up in the list of static routes. (10.0.0.1 is the Orbi's internal IP) If I enter the same IP and a 24bit subnet (255.255.255.0). Press apply and it is applied and saved. Shows up in the list of static routes.
