u-verse
2 TopicsAdding a WN3500RP to AT&T U-Verse...ugh! (ATT ATandT AT and T)
So...after a LOT of time trying to get my shiny new extender (the WN3500RP) to connect to my AT&T U-Verse network...turns out the problem was that the WPS feature (Wireless Protection Setup) was NOT EVEN TURNED ON! I don't know if this is a system default, or the way the tech set it up, but it is touted as a great "feature" of the router, so I have no idea why this would not have been enabled when the tech-guy set it up. To change the setup of your router: -type "192.168.1.254" into your web browser to manage the router. -go to "Home Network" tab -go to "Wireless" sub-tab -in the Wireless configuration, turn ON the WPS option (mine was off!) -SAVE the changes! (full disclosure: I have no idea what the PIN feature accomplishes, but I didn't mess with that.) -I restarted the router for good measure...then sure enough...I was able to connect the WN3500RP (as well as an almost-discarded printer!) just as easily as the normal WPS feature is supposed to be! (pressing the WPS button on the device, then on the router, and in a few minutes, they're connected.) Anywho, just wanted to share my experience/solution/nightmare so anyone who searches for a similar problem might be helped...and saved from jogging around the house hitting the same buttons over, and over, and over, and over...2.6KViews0likes3CommentsOrbi and UVerse Wireless Receivers
I've installed the Orbi AC3000 Tri-Band WiFi System with an AT&T Uverse system. I replaced the AT&T Wireless Access Point with the Orbi main Router and configured it for AP mode. After successfully syncing the 2 wireless AT&T receivers, they appeared to work. However, the problem that I'm looking for help with is that the wireless receivers will work fine for only about 5-10 minutes before freezing for a few seconds, then a notification pops up saying U-Verse signal is lost. This will last for several seconds before the screeen reverts to the OK screen for 2 seconds, then returns to the current channel and plays normally for another 5-10 minutes. Then the cycle repeats. I can bypass weird reset cycle by switching channels and quickly switching back when the screen does its inital freeze. Please help me with what settings do I need to change in either the U-Verse gateway or the Orbi AP to ensure my wireless receivers have continuous operation without these interrupts. Thanks in advance!Solved
