updating firmware
2 TopicsCan I update firmware for EX2700 without using a laptop?
Hi there, I've had a EX2700 N300 Wifi Range Extender for some time and it's been working fine. It's situated upstairs in my room and the main router is downstairs in the living room. Suddenly my devices cannot access the internet through it. All the lights are green indicating it's connected to the router and devices but the download speeds I'm getting are between 0.01-0.20mbps and uploads are 0.00-0.01 so I'm not able to do anything online upstairs at the moment. I haven't updated to firmware, to see if that helps, as I don't have a laptop to download it onto. Do you know of another way I can update its firmware or anything else you can suggest I try to get the usage back? Kind regards, Gary Crockford.1.1KViews0likes2CommentsUpdating Readynas Pro to Latest Firmware
I am currently running OS 6.6.1 on a legacy readynas Pro 6. When I do a check for updates it tells me that I am already running the latest firmware even through firmware viersion 6.7.1 is available. Do I need to do a manual update of the firmware to get 6.7.1 installed?Solved4.7KViews0likes10Comments
