warranty & contracts
53 TopicsMS305 overheating from new - no serial number!
I bought a new MS305 in January this year off Amazon UK and it's been overheating badly from new - REALLY hot to touch. (I've replaced with an MS308 now which is fine). So I've come to get support off Netgear only to find out that the unit has no serial number on the label and two screws missing from the back of the unit. To be clear, it came as new in a sealed package. I've got no way to get in touch with Netgear as there's no serial number. Any help/suggestions please.281Views0likes4CommentsRMA: Wrong Switch Sent and Support Can't Fix It
Hello! I have a GS324TP purchased in August 2023. It failed and support agreed to replace it. The replacement device was sent next business day. We're running in a very limited capacity without that switch so the quick turn around is good. The new device arrived and it was the wrong part (GS324P v. GS324TP). I can understand the mix-up. The reason for this discussion starts here. I was on the phone with support for about 45 minutes trying to get this resolved. They are unable to send the correct device until the wrong one arrives at the warehouse. The support rep asked me to hold twice while they talked to their superiors. The answer was the same. Their software won't allow them to replace the device today. Is there a Netgear support representative here who can help get the correct replacement shipped so we don't have to go another week in this state? Thank youSolvedM4300-24X Never buy a used one !
I bought a Year a Ago a used XSM4324CS Switch. It worked one Year, the Device is not booting anymore and has no Response on the Serial Connections. So I asked for Support, because of the unlimited Hardware Warranty. The Answer was for my very surprising, I bought through Ebay and that is not an Authorized Seller so no unlimited Hardware support. The Company, were i bought the Device, they bought it from an Authorized Seller and they don't want to provide there original Invoice. Any suggestions what to do ?1.1KViews0likes2CommentsWhy We Require Registration on Smart Pro Switches
NETGEAR has begun to require registration for manageable products due to enhanced concerns for security compliance and customer care in all regions of the world. An informational flyer is packed into all new shipping products. Learn more about why you should register your NETGEAR Switches and other business products. The registration requirement applies to the following products: Smart Managed Pro Switches Insight Managed Smart Cloud Switches Smart Managed Pro Switch with Cloud Management Smart Managed Plus Switches (Reg is recommended, but not required) The benefits to registering your switches are many including: Registration helps you keep your switch up to date and safe. We will be able to alert you if any new regulations are passed which require us to have additional security or privacy features. Registering helps you unlock switch warranty and support entitlements. We will be able to significantly simplify the process of getting you help if your product ever fails or needs troubleshooting. Registering switches gives you peace of mind. We will let you know about all new fixes or features which we add to your product and will supply you with links to let you upgrade. For instance, the recently added Insight Management options to certain smart pro switch firmware. Be aware that we take your privacy very seriously and we will never share your information with third parties. We also allow you to determine exactly what information we will send to you in the future. There are certain switch functions that will still be accessible for unregistered switches such as IP Configuration, Switch Soft rebooting, factory resetting and more. A full list here unregistered functionality of Smart Managed Pro Switches can be found here. To access the full configuration and management capabilities of your switch, register your switch to your NETGEAR account There are several options you can use when registering your switches. One of our favorites is with the NETGEAR Insight Remote Management App. Simply download on iOS or Android, then follow the on-screen registration instructions in the “Register any NETGEAR device on the hamburger menu. Insight makes it super easy to scan the QR code on the device with your phone. Or, if you have Insight Premium credits you can also register from www.insight.netgear.com. Note, *All NETGEAR devices can be registered with the Insight app, but only devices labelled as Insight Managed are fully manageable by Insight and included in the Insight subscription as a paid device. Learn more about the Insight solution and subscriptions at www.netgear.com/insight Other alternatives for registration of any NETGEAR product (including switches) by visiting mynetgear.com. Once there, you can create or login to a My Netgear account then use on-screen instructions to register your products. Finally, if you can also register your switches directly in its management screen as long as it has access to the Internet. From the local LAN (to the switch) browse to its IP address in a supported web browser. Instructions are included in the switch interface for registering the device. For additional information on these procedures and processes, please visit the NETGEAR Product Registration FAQ. Product Registration FAQ: https://kb.netgear.com/1160/NETGEAR-Product-Registration-FAQUnable to register GS324 ("Unable to register product to your account: Product not found.")
I have a new GS324 unmanaged switch, purchased a couple of weeks ago. When I try to register it, there is a popup error message that says: Unable to register product to your account: Product not found. I verified the serial number on the box and the product, they are the same.Solved2.4KViews0likes3Comments
