web interface
2 TopicsN900 (WNDR4500v2) Web Administration not accessible
Hello, Overnight, the router's Web administration server became inaccessible: the port 80 was closed, but everything else was still functioning properly (Wi-Fi, local connectivity and Internet, etc.). I had to change the configuration of the router so I tried a simple factory reset: the configuration of the router had been successfully reset, but I still do not have access to the administration Web interface. The router is now unusable since I cannot modify the configuration, and I can only use the router with the default configuration. I tried several techniques without success: factory reset, hard reset (30/30/30), TFTP (on Windows and Linux), connection by all LAN ports or by Wi-Fi, Netgear Genie, etc. Here is a nmap scan with all opened ports on the router: Host is up (0.0028s latency). Scanned at 2017-07-20 04:57:22 CEST for 6778s Not shown: 65527 closed ports PORT STATE SERVICE VERSION 53/tcp open domain dnsmasq 2.15-OpenDNS-1 548/tcp open afp Netatalk 2.2.5 (name: WNDR4500v2; protocol 3.3) 1990/tcp open tcpwrapped 5000/tcp open tcpwrapped 5916/tcp open unknown 8200/tcp open tcpwrapped 20005/tcp open btx? NetUSB 33344/tcp open tcpwrapped NetUSB MAC Address: C4:04:15:11:xx:xx (Netgear,) Service Info: OS: Unix curl http://192.168.1.1 curl: (7) Failed to connect to 192.168.1.1 port 80: Connection refused Port 80 of the Web administration interface is not open. I saw another person with the same problem but there is no solution: http://www.tomshardware.co.uk/answers/id-2988795/netgear-wndr4500v2-wireless-router-issues.html What can I do? Is the bug known? Thank you. EDIT: OK, just found this thead: https://community.netgear.com/t5/Wireless-N-Routers/WNDR4500v2-Router-Recovery-Using-UART-Serial-Converter/m-p/1296073#M25997 I will try this if no one has a better idea here :)SolvedNetgear r6400 web interface slow
Dear Smart people, Had Router about maybe a year, running latest firmware (V1.0.1.18_1.0.15) all of the sudden web interface slower than slow. Reboot doesn't resolve. No changes or getting creative with my config before issue started, just came out of the blue. Any help is appreciated.Solved5.6KViews0likes4Comments
