wifi extension
2 TopicsWifi extension to metal building
I have a WGR614G54 router. What's best way to get wifi inside building? It's around 50 ft from house, and I get wifi just outside the building. Electric panel in building is powered from a branch circuit in house main electric panel. So if it helps, they're on the same electric circuit.4KViews0likes2Commentsnetgear nighthawk x4 EX7300, leading to network performance issues
hello to all I have installed the nightwawk EX7300 wifi extender. the Wifi extension works fine but the original wifi signal is not working properly - the signal is identified - I can log into it with a PC or my mobile phone - I can go to google homepage, but all other websites don't work. Other devices cannot log into it. Any clue? Thank you for your help. John4.3KViews0likes7Comments
