wifi issues
2 Topics- Nighthawk X6 R8000 Wifi IssueHello, I am having issues with my Nighthawk X6 R8000. My cable modem is a Arris Surfboard SB6183. The problem I am having is Wifi devices will stop working. This occurs for 30 seconds to a few minutes. The Wifi will show connected, but the device will report no Internet during this time. During this time, the ethernet connected devices are not affected. The problem occurs on several wifi devices, not just one. This includes android phones and a Microsoft Surface Pro 4. The router was updated to the latest firmware to rule that out. When this occurs on the surface, the wifi icon has a yellow icon on top of it. When this was occuring, I was still able to ping the router from the surface, though Internet access did not work. Does anyone have any idea what is causing this (software or hardware problem) and how to fix it? Thanks, KevinSolved19KViews0likes11Comments
- Netgear C3700 on COMCAST - Please don't buy it !!PROBLEM SOLVED ! As you may have seen ive been having alot of issues with this device. The solution is DONT BUY this device if you are with COMCAST !. Here is why: 1. Slow speeds on wifi were due to an out dated firware version on the device according to NETGEAR (Tier 3 agent at the HQ in California) 2. After a FCC complaint that I filed; someone from Corp office at COMCAST called me. HE checked with his senior engineers and said that COMCAST does not have the latest firmware for the netgear device. He accepted that the firmware is completely handled (updated) by COMCAST and not NETGEAR (for the first time) 3. So basically dont use this device on COMCAST and if you want to but your own device in the future please check the compatible device which have been tested and passed with a 3 star rating at COMCAST website. link : http://mydeviceinfo.comcast.net Make: Netgear Model: C3700-100NAS (Retail) Retail: Yes Device Type: Gateway DOCSIS Version: 3.0 End of Life? No Certification: certification should have 3 stars according to COMCAST for that device to have the latest firmware on it ! If you look carefully on this list Netgear device is not properly tested at COMCAST and they will not be doing anything in the near future. However Motorola / ARRIS devices are fuly supported by COMCAST (becasuse they own 10-15% of ARRIS :D ) Sadly ARRIS devices arent the best and their wifi signal strength is absurb compared to some other providers. --------- I bought a Airport express router for $85 on amazon and this has fixed all my wifi issues. (thank you Apple) Basically im using a $150 device as just a dumb modem :( Only if I knew about this corporate mumbo jumbo earlier. God Bless America !20KViews4likes6Comments
