nzgroovejet
Jun 30, 2019Follower
404 not found error
When my phone is connected to my Orbi router (RBR20), some links I click on give me the 404 Not Found error. Any ideas? Firmware appears to be up to date (v2.3.5.26) Thanks
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Try a factory reset and setup from scratch...
Some link? So others work?
You say "my phone", what about other devices?
- Fl1ntstoneApprentice
Hi,
This is usually the reason of why you get 404 error:
The HTTP 404 Not Found Error means that the webpage you were trying to reach could not be found on the server. It is a Client-side Error which means that either the page has been removed or moved and the URL was not changed accordingly, or that you typed in the URL incorrectly.
CheerZ
- josedaInitiate
this answer is not correct. When I switch to a different network that doesnt uses the orbi router, i do not get the error
Any progress on this?
nzgroovejet wrote:When my phone is connected to my Orbi router (RBR20), some links I click on give me the 404 Not Found error. Any ideas? Firmware appears to be up to date (v2.3.5.26) Thanks
