wisetulip's avatar
Feb 15, 2021
after update of firmware
I updated my firmware on Orbi RBR20 since i am unable to see both icons for router and sattelite on iphone app.  i just see text " Satelite 1" and the modem with waves around it.  the update was done on February 8.  i am not certain if my satellite is working, and if it is the reason I am no longer able to view both icons showing they are connected.  the main and the satellite icones- and only see one now. thank you
  • Have you powered OFF the ISP Modem and RBR for 30 seconds then back on with the modem first, then the RBR?
    How was the system updated? Orbi app or thru the RBRs web page?
  • FURRYe38's avatar
      • FURRYe38's avatar
        Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed.
        Enjoy. :smileywink:
    Revert back or spend hours answering questions
