wisetulip
Feb 15, 2021Tutor
after update of firmware
I updated my firmware on Orbi RBR20 since i am unable to see both icons for router and sattelite on iphone app. i just see text " Satelite 1" and the modem with waves around it. the update was done...
- Feb 15, 2021
Have you powered OFF the ISP Modem and RBR for 30 seconds then back on with the modem first, then the RBR?
How was the system updated? Orbi app or thru the RBRs web page?
wisetulip
Feb 15, 2021Tutor
Your solution worked thank you very much
Feb 15, 2021Guru - Experienced User
Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
- wisetulipFeb 15, 2021Tutor
"Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed."
how do I perform above on iphone app? i can only access/view my account on iphone app.
the login.net only brings up the netgear website now.
- FURRYe38Feb 15, 2021Guru - Experienced User
You'll need a PC or laptop to connect to the RBR to perform a back up. If you can connect a PC or laptop, you'll find the Backup feature under Advanced Tab/Administration using a web broswer.
wisetulip wrote:"Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed."
- vajimFeb 16, 2021Master
FURRYe38 wrote:You'll need a PC or laptop to connect to the RBR to perform a back up. If you can connect a PC or laptop, you'll find the Backup feature under Advanced Tab/Administration using a web broswer.
Keep an eye on it
good luck
- BoilerPlateFeb 15, 2021Apprentice
Vajim's lack of knowledge and experience, your mileage may vary. >vajim. User beware. :smileysad:
Historical posts prove it:
https://community.netgear.com/t5/Orbi/Orbi-RSR50-firmware-2-5-1-16/m-p/1903734/highlight/true#M90556
https://community.netgear.com/t5/Orbi/Problems-with-new-Orbi-RBK53-setup/m-p/1876257#M85028
https://community.netgear.com/t5/Orbi/Constant-VPN-reconnecting-since-upgrading-to-firmware-V2-5-1-8/td-p/1879290/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Netgear-drops-the-ball-again-RBR50-on-FW2-5-1-8/td-p/1876302/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Orbi-RBR50-was-working-amp-changed-modem-now-not-working/m-p/1887710#M87429
https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speeds-Drop/td-p/1891090/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/dropped-bandwidth-on-Orbi-RBR50-with-cm1000-modem/m-p/1901910#M90201
https://community.netgear.com/t5/Orbi/Orbi-RBR50-bricked-during-update-to-2-3-5-30/m-p/1897073/highlight/false#M89235Sad that he has to spread false and inaccurate information and badger and troll others that are just providing help to others. Must have a sad life.
:smileysad:
