frankds
Aug 14, 2018Follower
Airplay is still not working - any fix expected?
I got two Orbi setups; Finally the WiFi is going trough the walls but Airplay is NOT working at all; mostly the devices are not even discovered (not even from Windows Airport admin tool) or if they are it breaks down after some time. Tried all tips (RTS, All beamforming mumimo etc combinations) As this seems to be a general issue, when will it finally be fixed? This is not acceptable at a system this price...
- DarrenMSr. NETGEAR Moderator
I will look into this and will let you know what I find out.
DarrenM
- highhriderAspirant
I bought the ORBI AC3000 from Costco about 1 week ago. None of my Airplay devices works. I have Airplay devices that are wired and wireless and neither worked. My wired Airplay devices were discovered up but I would receive an error when trying to connect. My wireless Airplay devices were not even discovered.
I went back to my Airport Extreme routers, and my Airplay started working again.
There is definitely a bug in the ORBi system with Airplay.
The ORBI set has been returned to Costco.
