BSmithline
Dec 14, 2017Aspirant
ALERT TO USERS RBR50/RBS50 you may have to do a manual FIRMWARE update
ALERT TO USERS RBR50/RBS50 your systems may not show that a NEW firmware update is advalable when under Advanced / Firmware you choose "CHECK" I had to do a manuel update. I know that the averag...
jvaudio
Dec 16, 2017Tutor
I updated one of my RBS50 satellites to the lastest firmware manually. When I went to update the other one, the popup fails to load - the dialog just shows the code for the popup. I've disabled ublock origin and allowed popups for orbilogin, but this issue remains. I tried Chrome, Firefox 57, Vivaldi, and Edge.
I was able to update the RBK50 firmware, but now I have one satellite on 2.0.0.74 and one on 2.1.1.12. Does anyone have any ideas or suggestions?
Thank you
- ElyDec 16, 2017Luminary
Just download your satellite's firmware manually from the Netgear site, then visit your satellite's page by going to its IP address and click on "Firmware Update" on the sidebar, upload the file you just downloaded click update and presto!
- jvaudioDec 16, 2017Tutor
Hello Ely,
Thank you for your reply.
Yes, I have tried that, but I still receive the same error. It gives me a 401 authorization error but I am never given a dialog to log in. I've attached a screenshot of the error that I am experiencing:
Thank you
Have you tried cleaning up your browser's cache and cookies? have you tried rebooting both the router and the satellite? disconnect your router from the power then disconnect your satellite, after 30 seconds reconnect your router, then turn the satellite back on and try to do the manual update again.
PS: What I see on that screenshot is plain HTML Code, your browser should not be displaying it like that, something is not right, have you tried doing this from a different machine?
