theronin_hunter
Jul 31, 2017Tutor
Alexa - Multiple routers found
Hi,
If i activate the Skill and ask Alexa to activate my Guestnetwork, there is the following comment: "There are to many Routers found." - I only have Orbi in my house.
Any Ideas?
- DarrenMSr. NETGEAR Moderator
Hello Theronin Hunter
Can you check the settings in Alexa see if it has multiple wifi connections saved?
DarrenM
Hi,
No single wifi network stored
Any other ideas?
