jmchez
Mar 15, 2017Tutor
Any Plans for ORBI Firmware Upgrade for guests on WiFi to see each other WITHOUT accessing the LAN?
Are there plans for a firmware upgrade to the RBR50 firmware to allow guest to see ach other wihtout having acess to the main Lan? If the answer is no because this is a limitation of the product...
peteytesting
Mar 25, 2017Hero
jmchez wrote:Are there plans for a firmware upgrade to the RBR50 firmware to allow guest to see ach other wihtout having acess to the main Lan?
If the answer is no because this is a limitation of the product, I will start to see how to recoup my $300 dollars and sell the ORBI set. I hope that it doesn't come to that.
this actually doesnt make sense as you wouldnt want guest access to the lan or each other , the whole concept of guest isolation and guest wifi is built on this in most domestic wifi
in more soho / prosumer type gear you can use vlan and do what ever you want but this features is found on a different class of gear
