Deckard22's avatar
Deckard22
Apple devices disconnect from satellite
Hello! My iPhone SE and iPad 2 seem to have trouble staying connected to one of my Orbi satellites. I can be sitting two feet away from the satellite and will drop a bar, and sometimes disconnect entirely for several seconds. I have two satellites, and this is the only one that behaves like this.
I did a factory reset a couple of months ago, and the problem persists. Any advice? Thanks in advance!
    • thebbandj's avatar
      thebbandj
      Initiate
      I have been struggling with my iOS devices showing full strength wifi, but no connection for some time now in a room that is equal distances from the router and satellite.
      I had already disabled:
      - Beamforming,
      - MIMO-MU,
      - Daisy Chain,
      - Fast Roaming
      And went in and changed the following settings:
      - Set 20/40Mhz Coexistence to 40Mhz only.
      - Changed CTS/RTS Threshold to 2307 for both 2.4GHz and 5GHz
      The problem is gone. I am going to see if it is the combo of the two or just one, but very happy this is solved.
      • FURRYe38's avatar
        Now what happens if you re-enable Beamforming only with those other settings?
        - Beamforming,
        - MIMO-MU,
        - Daisy Chain,
        - Fast Roaming
