TeamLevine
Aug 02, 2018Aspirant
AT&T Uverse Cable Not Working With Orbi RBK50 (AC3000)
When connected through my Orbi RBK50, my AT&T Uverse cable is not working. Does anyone know how to get all Uverse receivers working properly with the Orbi router (NOT in AP mode) based on the setup b...
Aug 02, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Option #2 would be your best option.
ALSO:
Disable IGMP on Managed Switches with your GS116v2:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
TeamLevine
FURRYe38... My apologies if I wasn't more clear re the specific issue...
Other than my Uverse cable TV not working, my Orbi network is functioning very well. The Pace router/modem has delegated network management to Orbi and all of my internal IP addresses are 10.0.0.X.
I've attached a device list from my Pace router/modem - the router is listed as it should be (I'm assuming). The "uverse_NODE..." is the Uverse receiver in the Media Room connected directly to the Pace (only possible to do this in the Media Room). Since it's connected to the Pace it's working fine.
Also attached a partial device list for the Orbi. As you can see, most of the devices I reference on the Network Map are shown here. The devices highlighted in yellow are the other Uverse receivers in the other rooms that are not working.
Let me know if any addt'l info will help you to help me! Thx!!!!
Devices on the Pace Router/ModemDevices on the Orbi Network
