atleasttwochara's avatar
Aug 10, 2020
Blocked Service but imessage goes through
I've blocked services on a schedule and it blocks web browsing but imessage still work.  How can stop all services?
    Does this pertain to your Orbi or an iPhone? Blocking services on the Orbi is limited. Normally phone blocking takes place on the phone itself. Don't be confused by the IP_Phone block on the Orbi as it is for VOIP phones.
    • atleasttwochara's avatar
      atleasttwochara
      my netgear product is actuall RBR10 dual band system but wasnt in drop down.  Devices affected are wi-fi only ipads and are able to text even though services are blocked.
      • Mstrbig's avatar
        Mstrbig
        Master
        When you say text, are you referring to Apple's communications system, like Facetime, Imessage, etc?
        If so these are the ports open. Possibly blocking these will give you the results you need.
        FaceTime:
        80 (TCP), 443 (TCP), 3478 through 3497 (UDP), 5223 (TCP), 16384 through 16387 (UDP), 16393 through 16402 (UDP)
        iMessage:
        80 (TCP), 443 (TCP), 5223 (TCP)
  • CrimpOn's avatar
    CrimpOn
    Can you describe the way the service block was implemented.  If you want a certain WiFi device to be "cut off" for certain hours of the day, I would think the block should be "Any" from "1" through "65535" for "TCP/UDP" and you would specify the IP address of the iPad to be controlled.
      atleasttwochara
      Hi - Under LAN set up I assigned my kids devices IP addresses in a range.  I also set up a schedule and then under blocked services setup I blocked the range of IP addresses per schedule.  It seems to work for web browsing and most apps but they can still send imessages even on wifi only iPads.
      The blocked services are
      Type = Any
      Protocol = TCP/UDP
      starting port = 1
      ending port = 65535
      The type is the only field I can change.
      • Mstrbig's avatar
        Mstrbig
        Master
        I tried and was not able to block i-messages or facetime
