JulietteT
Apr 12, 2020Aspirant
BT Home Hub conflict
Please can anyone help?
I have sucessfully-ish installed my Orbi plus 2 satelites. I am currently using a BT Home Hub and this is causing some issues - can't print, can't access some websites (error code 404), and can't connect to my smart tv or bluetooth speaker.
I have tried disabling the wifi on the Home Hub router and I have tried with the wifi enabled.
Can anyone suggest what else I could try? I am happy to replace the Home Hub with a modem if this might help.
Many thanks
disabling wifi doesn't disable the routing aspect of the home home. it leaves you in a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
2 easiest options are 1. put the home home in passthrough/modem only mode or 2. put the orbi in access point mode.
Easier said than done, if not impossible with the HomeHuib. BT goes out of its way to deny users that option .
That works fine for many Orbi users. I don't have a HomeHub. (I've got three of them, two still shrink wrapped.) But I still have an AP Orbi network.
- JulietteTAspirant
Thank you for the help.
Yes, I think putting the homehub into modem/passthrough mode is impossible.
Do you have any advice on how to do your second suggestions? I am not a techie at all so just stumbling through this progress while my family moan and complain about the pages they cant access!!! (To be fair, my eldest cant get logged onto her Uni library which is not helping her Masters dissertation much!!)
I'm sure there must be a solution.....
Thanks
Juliette
