hookalot's avatar
Jan 02, 2018
*BUG* 2.6.1.16 SSID Name Character Limit Change
Count me in as one of the folks whose system was auto updated from firmware 2.0.0.74 to 2.1.1.16.  I'm also experiencing from the various other issues reported, but wanted to touch upon this particular issue concerning the wireless SSID character limitation/display issue I'm experiencing.
Prior to the firmware upgrade to 2.1.1.16, I had a 17 character SSID brodcast name.  After the firmware upgrade, my SSID name was chopped down to only 15 characters (last 2 characters were dropped off).  It took me a bit of troubleshooting to figure out why my wireless devices were not connecting to my known network, and that’s when I discovered the discrepancy in SSID name.
Oddly enough, I was able to go into GUI and re-apply my original 17 character SSID name, and my devices were able to re-connect as expected.  However, the GUI SSID Name textbox is still only displaying the first 15 characters, despite the system broadcasting the 17 character name.
This sounds like a simple character length/display coding issue that was introduced in this version that will hopefully be trivial enough to correct.  I would appreciate if others could duplicate this issue and acknowledgment from the Netgear Support/Dev team that this is an issue they will investigate.
Equipment: RBK50  in Router Mode
1 x Orbi Router (RBR50)
1 x Orbi Satellite (RBS50)
  • Replicated and confirmed.  :catmad:  There is a bug in the maximum SSID length.  There's an additional bug in the maximum password length, too.  I could not "fix" the password bug by typing my long password in the password field.  When I tried to apply the changes for both my "long" SSID and "long" password, I got a web browser error (in Chrome, Firefox, Opera, and Edge).  I ended up reverting back to firmware version 2.0.0.76.  :catmad:  The IEEE 802.11i-2004 defines WPA2 passwords as being 8-63 ASCII characters or 64 hex characters.  The IEEE Std 802.11-2007 defines the maximum SSID length as 32 charaters.  I would've though these would have been part of the firmware release acceptance test suite 10+ years ago. :catmad:
