bhenry
Dec 24, 2017Tutor
Can I combine backplane methods in my orbi network
With the newest firmware I have gone to using my orbi in AP mode with my comcast high speed 250 down for the house. The orbi router was proving not up to the task for some reason while using the modem...
bhenry
Jan 11, 2018Tutor
So if I am using my Comcast as the router and hading out IP's, the Orbi router is just acting as the AP, you would plug one satellite into the router wired, turn on daisychain, and then could operate a two satellite/one routr system in one satellite on wire and one on wireless backplane?
DarrenM
Jan 11, 2018Sr. NETGEAR Moderator
That is correct.
DarrenM
