IdaS
Apr 23, 2019Aspirant
can I combine Orbi systems
Hi,
I have a Netgear Nighthawk with a Netgear extender but still nooks and crannies in my home without Wifi. So I am thinking of buying an Orbi system. A perfect setup for my home, at least on paper, would be an RBK50 router, with 1 Orbi voice and 1 Orbi RBS20 and 1 Orbi RBW30. Is this workable, or are there problems when combining these componenets of different systems. I have scoured the internet but couldn't find a satisfactory answer to this question.
Thanks for your feedback.
Yes you can combine them. I would keep the satellites the same however if you get a RBK50. The wireless rates are different between a 50 series satellite and a 20/30 series satellite. I would get a RBS50 satellite if you need an additional satellite. The RBK50 somes with 1 satellite in the box.
30 feet is recommended in between base router and satellite to begin with depending upon building materials when wirelessly connected.- IdaSAspirant
Hi Furry,
Thanks for your quick reply. My home setup it a bit strange, that's why the Nighthawk + extender can't get everything covered. It are two separate small cottages with a room connecting them. Looks like an H, with extra floors on the legs of the H. I like the design of the RBS20 more than the bigger RBS50, that's why I hoped this could be a workable setup.
What is the model of the NH and EX units you have now?
- IdaSAspirant
Thanks for making my extremely jalous ;). Already bought the Orbi's I want to use now.
You'll be good with the one you have.
Enjoy. :smileywink:
- gr8shoVirtuosoOkay fine, but my comment wasn't about the upcoming product release but rather about the generality of using the term future proof as it pertains to hardware. 😉
