MStech's avatar
MStech
Can I use two RBS50 in 1 RBR50?
Hi All,
So I bought two RBK50 systems. Each system comes with 1 RBR50 (router) and 1 RBS50 (satellite). My question is, is it possible to use the 2 RBS50 to connect to the 1 RBR50? Or are the RBS50 paired only to the RBR50 that came together in the pack? Addittionally, can i setup the other 1 RBR50 as another satellite making the entire system as 1 router (RBR50) and 3 Satellites (2 RBS50 + 1 RBR50). Thanks in advance
  • Hi,
    you can have the 2 RBS50s as satellites for one of the RBR50s.
    The 2nd RBR50 however cannot be used as satellite.
