tcander
Apr 14, 2018Aspirant
Can't get Orbi to work with Circle
I have Android 8.1.0 and I can't get Orbi to work with Circle. I open Circle app and click "Get Started". It says make sure you are connected to your router, which I am. So I click Next. Then it ...
Apr 14, 2018Guru - Experienced User
What FW version are you using?
Try setting up Circle on the router first with a PC and a web browser connected to the routers web page.
- tcanderApr 14, 2018Aspirant
My firmware version is:
V2.0.1.4
model rbk50
I do not see any way of setting up circle via the web interface.
how do I do it that way?
- raven_auApr 14, 2018Virtuoso
tcander wrote:My firmware version is:
V2.0.1.4
model rbk50
I believe Circle is implemented in the recent Orbi 2.1 updates, it wasn't yet included in 2.0.
- tcanderApr 15, 2018Aspirant
That is odd. I guess there is a newer update on the website. But I have refreshed the updates via my router's web console and it said there were no new updates:
Router RBR50 RBR50 V2.0.1.4 No new firmware version available. Satellite RBS50 RBS50 V2.0.1.4 No new firmware version available. I guess I have to manually update it?
- FURRYe38Apr 15, 2018Guru - Experienced User
I think you'll find what you need here:
https://www.netgear.com/support/product/circle.aspx
If you still can't get this going, I would phone contact NG support.
