tcander
Apr 14, 2018Aspirant
Can't get Orbi to work with Circle
I have Android 8.1.0 and I can't get Orbi to work with Circle. I open Circle app and click "Get Started". It says make sure you are connected to your router, which I am. So I click Next. Then it ...
tcander
My firmware version is:
V2.0.1.4
model rbk50
I do not see any way of setting up circle via the web interface.
how do I do it that way?
raven_au
Apr 14, 2018Virtuoso
tcander wrote:My firmware version is:
V2.0.1.4
model rbk50
I believe Circle is implemented in the recent Orbi 2.1 updates, it wasn't yet included in 2.0.
- tcanderApr 15, 2018Aspirant
That is odd. I guess there is a newer update on the website. But I have refreshed the updates via my router's web console and it said there were no new updates:
Router RBR50 RBR50 V2.0.1.4 No new firmware version available. Satellite RBS50 RBS50 V2.0.1.4 No new firmware version available. I guess I have to manually update it?
- FURRYe38Apr 15, 2018Guru - Experienced User
Yes you have to manually download the files from NG support site if you want to use v2.1.3.4. Needs to factory reset the router and satellite after updating FW then set up from scratch. I would use IE11 or FF browsers to do this.
Please be wire cable connected to the router and satellite when updating FW.
tcander wrote:That is odd. I guess there is a newer update on the website. But I have refreshed the updates via my router's web console and it said there were no new updates:
- raven_auApr 15, 2018Virtuoso
FURRYe38 wrote:Yes you have to manually download the files from NG support site if you want to use v2.1.3.4. Needs to factory reset the router and satellite after updating FW then set up from scratch. I would use IE11 or FF browsers to do this.
When I go to the Netgear web site I see v2.1.3.4 as the current release but it seems others do not
or perhaps it's becuase it hasn't been enabled for automatic update?
In any case support seems to be unaware of the availability of the new version cuasing unproductive
exchanges.
Support really need to be aware of what engineering is doing or you may lose valuable infomation ....
