tcander
Apr 14, 2018Aspirant
Can't get Orbi to work with Circle
I have Android 8.1.0 and I can't get Orbi to work with Circle. I open Circle app and click "Get Started". It says make sure you are connected to your router, which I am. So I click Next. Then it ...
tcander
My firmware version is:
V2.0.1.4
model rbk50
I do not see any way of setting up circle via the web interface.
how do I do it that way?
Apr 15, 2018Guru - Experienced User
I think you'll find what you need here:
https://www.netgear.com/support/product/circle.aspx
If you still can't get this going, I would phone contact NG support.
