ngstuff
Sep 25, 2017Aspirant
Can't login to RBW30
Hello, I have a RBW30 sattelite unit (current firwmare 1.12.0.4). I'm trying to get it updated to the latest firmware version (as of now the new firmware to loadRBW30-V2.0.0.34_1.0.21). However each ...
ngstuff
Sep 26, 2017Aspirant
Yes, tried to login directly @ ip address but that did not work either - languages are not an issue as I can loging to my other satellite without any issues. The password from the main router does not seem to have synced
Thanks for your response
aaz
Sep 26, 2017Virtuoso
If it's not synced you would see a light on the satellite, should you not?
- ngstuffSep 27, 2017Aspirant
Password is not synced -
- aazSep 27, 2017Virtuoso
Probably still worthwhile to treat them as if they are complety unsynced.
Guide on synchronizing Orbi router and satellite- Ensure that both the Orbi router and satellite are powered on.
- Press the Sync button located on the router.
- Wait for two minutes and then press the Sync button on the satellite.
- Your Orbi router and satellite have been successfully synchronized.
