jjh636
Jun 30, 2020Tutor
CBR40 with 2 RBS20 connection loss and slow speeds
Hello,
This has been an ongoing issue - bought this modem/router in feb and since then it has lost connectivity ~ 4-5 hours at a time at least once or twice a month. Everytime this happens, I check with my ISP - no service outages, they resend a new signal, etc, should have no problems on their end. Has any one else been having this issue?
It just happened again this morning (Magenta color) and after unplugging, replugging everything multiple times, calling Xfinity, I gave up and went out and bought a new modem. When I got back the CBR40 was still not working, took a shower came out and then out of the blue, 6 hours later it was working.
Normally I wouldn't complain if this was a one-off, but it seriously happens every 2-4 weeks. Is there any way to prevent this? I'm ready to return this thing.
Also, wired connection speed is fine at 600mbs, however wireless ranges from 75-200. Is this normal? This is the case even if I am right next to the satellites. Firmware is updated.
Your line is a bit low on power. the notices from the event log point to a signal issue.
If you have any splitters, attenuators, amplifiers in line, remove them.
Your isp might need to check the line.
When its dropping, is it just wireless or is it both wired and wireless devices?
Do you have a screen snip of the cable connections page? And the logs? this helps check the signal back to xfinity.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- jjh636Tutor
Satellites are within 30 feet
Any Wifi Neighbors near by? If so, how many?I changed it to 1. There are Wifi neighbors nearby, aroun 3 or 4.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).I enabled Beamforming and MIMO. set to 40 Mhz, set to short preambles, disabled fast roaming. Ipv6 is already disabled, Not sure where to find the Armor or Circle options. After disabling Dasiy chain my satellites weren't being picked up.
My wifi speeds are pretty abysmall now, raning from 50 - 150. I pay for 600.
What wifi devices do you have?
Do wired PC test speeds test out to 600Mpbs?
RBS may need to be moved out past 30 feet.
Some wifi devices may not speed test out to 600Mpbs. Some max out at around 400-500. Older phones or pads may not see much over 200Mpbs. I know my one pad sees usually around 150Mpbs on wireless. https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
