lineaux's avatar
lineaux
CM1100 and Orbi RBR50 - recommended settings
Hello,
I have an existing  currently working almost flawlessly (on AP mode) with an att uverse gateway.  A very straightforward setup.
I will be moving to xfinity internet soon and already purchased CM1100 (from Costco).  I plan to connect the same Orbi RBR50 (+1 RBS50) to the CM1100 (cable modem).
I believe I would need to switch the RBR50 settings back to Router mode before I move to connections from the att gateway to the CM1100, correct?  Will there be any problem if, for some reason, the RBR50 was left on AP mode when moved to the CM1100?
I would also like to seek for recommend settings (if any) on either the CM1100 or RBR50.  At the start, I plan to keep the connections/setup simple then experiment on some advanced settings later on.
Thanks
  • A power OFF of the modem for 1 minute then back ON maybe needed to effect this.
  • FURRYe38's avatar
    Yes the RBR needs to revert back to router mode if you connect it to the CM1100.
    Disable LAG on the CM modem and be sure to connecdt to WAN #1 port on the CM modem with the RBR.
    Be sure to power OFF the RBR after setting router mode. THen connect to the CM modem. Power the modem ON first and besure it's activated by the ISP correctly. After the modem is online fully, then power ON the RBR. It should get internet services with out any other changes.
    This would be all thats needed.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • lineaux's avatar
      lineaux
      Thanks for the information.  I have noted the LAG setting on the CM.
      I wanted to make sure that aside from changing the RBR settings from AP to Router mode, no other changes are needed.
      Also, I just remembered that I need to ask the tech about the CM FW update.  I assume that the  CM only have the 'default' FW version loaded (V2.01.02) out-of-the-box.  I wonder if the comcast-deployed FW (V6.01.07) is automatically uploaded during activation.
      • FURRYe38's avatar
        ISPs are reqponsible for FW updates on cable modems. There is no user appliable FW updates for modems. Some ISP may not push FW udpates to user owned modem. Contact the ISP for further information regarding this.
        Good Luck.
