CarlM1975
Feb 01, 2022Initiate
Compatibility of satellites with Orbi RBR20 Router
Hi
I have a RBR20 Router and 2 RBS20 satellites, I want to purchase another satellite but Im having difficulty finding one anywhere. Can I buy and use another satellite, for example RBS50?
Does anyone know which satellites would happily work with the RBR20 Router?
Thanks in advance
Compatible satellites:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
You can also use the EX7500, EX7700, EX8000 but they don't "integrate" with the system but function as their own mesh.
- CarlM1975Initiate
Thanks very much, this is extremely useful
- gupshupAspirantThanks for the post.. i have rbr20 & 7700. Just curious what the performance hit would be, when combined, compared to rbs20/rbr20. Thanks for your time
I've never tested the performance difference from using the official rbs20 satellite to using the ex7700.
The have the same width backhaul/fronthaul so if you're only using 1, it shouldn't be a whole lot.
