hgandhi204's avatar
Aug 01, 2019
Connecting hard disk to Router
Hello All,
I have just completed the setup of Orbi RBK 50 and 1 satelllite. I had ASUS router which had USB 3 and USB 2 ports through which I connected my hard disk and used it over the network. I know there are different reports regarding the USb functionality on the Orbi router.
I currently have a network switch which is connected to Orbi router and many devices are connected to the switch including my ASUS router.
My question is that when I connect my HDD to the ASUS router I dont see it on the network probably coz of different IP address of different routers? or soemthing. I would like to access the hard disk on Roku and android TV which do not detect the HDD on the network.
Any solutions? help or ideas is very much appreciated
Thanks
HG
  • Retired_Member's avatar
    Retired_Member
    hgandhi204 wrote:
    Hello All,
    Thanks
    HG
    Are you still using the ASUS router with the Orbi ROUTER??
    • hgandhi204's avatar
      hgandhi204
      Tutor
      Yes, I have connected my ASUS router through the network switch which gets its connection from Orbi
  • FURRYe38's avatar
    Orbi doesn't support USB drives.
    You'll have to contact ASUS to see how they support and configure there router for USB drives. I presume if your wanting to use the ASUS as your USB drive support, you may want to configure that router for AP mode.
        hgandhi204
        Tutor
        Yes, I was aware of Orbi not supporting USB drives, that is why I connected my ASUS router.
      hgandhi204
      Tutor
      Yes, I was aware of Orbi not supporting USB drives, that is why I connected my ASUS router. I used the ASUS router before Orbi and connected the drive which worked fine for 1 year. I will research about AP mode. Thanks
        Retired_Member
        Nice....AP mode is required IF you must run 2 routers.  In most cases running 2 routers on a network can be like having 2 queen bees in the same hive.  Will not work.
      Retired_Member
      FURRYe38 wrote:
      Not officially supported by NG.
      so only posts by you are supported?
        hgandhi204
        Tutor
        I didnt understand your question? ASUS router supports HDD, thats why I connected it to network switch through orbi
