Sdpoorman's avatar
Sdpoorman
Connection issues
I have had the Orbi system for almost 8 months with no issues. Everything worked perfectly in my 1500 sqft home. Recently I have started having issues with my the WiFi dropping off of my phone and other devices. I can be 2 feet from the device and it will drop out, reconnect and drop again. The software is up to date and I continuously pull between 90-170mbs wirelessly. Any suggestions and to the cause? It’s starting to get really annoying.
  • Would be useful to know your configuration -- make model of cable modem, make model of Orbi, Firmware version and if you have satellites.
    Once we know that, the configuration of the GUI (advanced wireless) settings would be useful to know.
    • Sdpoorman's avatar
      Sdpoorman
      I have an Arris Surfboard model SB6141.
      My Orbi model is an RBR20. Firmware version is 2.2.1.210. I have one satellite in my house as well.
      • ekhalil's avatar
        ekhalil
        Master
        - What wired devices do you have connected to Orbi please?
        - Do you use wired or wireless backhaul between router and satellite?
        - As asked by Chuck_M , can you please list what settings you have under >> ADVANCED >> Advanced Setup >> Wireless Settings >> in the web GUI (orbilogin.com)
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
      Sdpoorman
      Home is about 1300sqft, wood frame. Very open. The router and the satellite are about 20 ft a part. It had been working fine and these issues just recently started.
      Can I change all those settings in the app? I was looking for the options to do that and couldn’t find where to.
      • FURRYe38's avatar
        I would move the satellite a bit farther away, 20 feet is too close. 30 feet is a good starting point for placement.
        To make changes you'll need a PC or latop connected to the router and use a web browser to make changes at orbilogin.com in the browser.
