pburgh19's avatar
pburgh19
Constant dropping (wired and wireless) with two wireless satellites and one wired
I've been having an issue with daisy-chaining not working quite right, so I decided to hardwire one of my furthest satellites back to the RBR50 base.  At first, everything was good and the hardwired satellite provided increased performance.  However, a few hours later the system started dropping all over the place.  Wired and wireless connections are affected.
If I turn off the hardwired satellite, things settle down and performance is fine.   Why would this be?
A quick run-down of the archicture:
Orbi RBR50 is connected directly to the modem.  One LAN port is connected to an 8 port Netgear switch.  That switch is connected to two Netgear PoE switches (for security system).  The hardwired satellite is connected to a non-PoE port on one of the PoE switches.  There are no other DHCP servers on the network.
Here the Orbi gear I'm running:
RBR50
FIrmware: V2.1.4.16
Satellite RBS50 (3 units)
Firmware: V2.1.4.16
Satellite RBS50Y (1 unit)
Firmware: V2.1.4.16
  • FURRYe38's avatar
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Daisy chain has to be disabled if your using wired connections between router and satellites.
    • pburgh19's avatar
      pburgh19
      Answers in bold
      What is the Mfr and model# of the IP modem the Orbi is connected to?
      Technicolor DPC3216 (from Spectrum in Maine)
      ~5,000
      The one that is hard-wired is 140' away from the router.
      Using Auto, will try manual
      None
      Will try that as well, thank you
  • FURRYe38's avatar
    I would also set up a IP address reservation for the satellite(s) ON the router. This could be an issue maybe if there is a IP address conflict with the satellite and another device...
    • pburgh19's avatar
      pburgh19
      And that's reserved using the satellite MAC address, correct?  There's no way to assign a static IP on the satellite as far as I've seen.
      • FURRYe38's avatar
        Reserve IP address of the satellite ON the router.
