lepack
Feb 13, 2018Aspirant
Converting from Circle box to Circle on Orbi
I’ve been using a Circle Disney box connected to my Orbi router before it became avalaible as part of a recent software upgrade. My question is how do I switch my Circle box over to the Orbi directly? Is it as simple as disconnecting the Circle box and enabling the Circle feature on Orbi? The Circle box has battery backup so I’m concerned about having two instances of Circle running. Will the Circle app automatically recognize the new switch over to the Orbi setup?
- troublesGuideIf the circle box works keep using it. The installed version is subscription based, except for some of the basic features.
