lgrip's avatar
lgrip
Disable 5 GHz Oribi RBR53
Model RBK53 Orbi Router with 2 satellites, Firmware V2.1.4.16 with a computer running Windows 10. I have a RBK53 Orbi router.  I have a new device which I need to connect to the router. The new device will only concect on 2.4GHz band. To connect the device I need to disable the 5GHz band.  How can I temporaley disable and then reconncet the 5 GHz band.
  • michaelkenward's avatar
    michaelkenward
    There is a manual for the Orbi WiFi System somewhere at the end of this link:
    >>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
    There should be no need to disable 5 GHz to get something to connect to the 2.4 GHz. If the device can't see 5 GHz, it won't try to connect.
    Then again, it might help if you said what that "new device" is and why you think you need to disable 5 GHz.
    PS For the benefit of anyone else trying ti help, there is an error in the subject, RBR53 should be RBK53, as it says in the text.
    • ARF's avatar
      ARF
      I haven’t found a way to turn off the 5ghz but one work around is to login to Orbi and change the transit power of 5ghz down to 25% while you setup new device.
  • The device which I am attempting to connect is an Ambient Weather WS-0262A WiFi Wireless Therm-Hygrometer.  The manuel explicitly states that on dual band routers the 5 GHz band must be disabled and enable the 2.4 GHZ band only.  I have reviewed the manuel for the router and do not find any way that only the 5 GHz band can disabled. I am stilll looking for a way to disable 5GHz on the RBK53 Orbi Router
      michaelkenward
      Have you tried setting it up without doing that?
      As you present it, the manual seems to suggest that you should turn off 5 GHz permanently. That is nuts. It does not make sense even to temporarily disable 5 GHz.
      As I said before, if the Ambient Weather WS-0262A works on 2.4GHz, it will not even see the 5 GHz
      Orbi routers seems have the same features, they certainly share a manual. On the RBR40 you can disable the 5GHz SSID broadcast:
      >>Advanced >> Advanced Setup >> Wireless Settings.
      I have no idea if this will achieve this strange result.
      • lgrip's avatar
        lgrip
        I understand that the Ambient Weather should connect to 2.4 GHz and not see the 5 GHz. But, I have attempted to connect the Ambient Weather and it will not connect. I have Disabled 5 GHz SSID broadcast, and reduced the power of the 5GHz to 25%. The Ambient weather will still not connect.  I wish that Netgear Inc. would respond and help with this issue, How to Temporally  Disable the 5GHz .
