Jayhawk87
Mar 19, 2021Aspirant
DNS stops working
About 1 week ago started to have issues with my Orbi stopping DNS resolution. I am running the latest version of firmware (V2.7.2.104) and running Armour Security. I do have DNS setup to the router. I have seen couple of other discussion strings on this topic but really never saw a true "fix" for the issue. Any ideas or fix?
Correct. This is a raging issue right now. A good summary of possible solutions can be found in this post:
II have just seen posts suggesting that disabling Traffic Meter (in the Advanced Setup Menu) might help.
It is pretty clear that *something* is happening that mangles the DNS process.
No official solution from Netgear so far.
- Jayhawk87Aspirant
Thanks for the link to the possible solutions. Best solution would be for NetGear to fix the issue all together. I am trying the disabling of the NTP auto adjustment for daylight savings time. We will see if that helps or not.
- robertneavesAspirant
Same problem!
- vajimMaster
Netgear will fix it....until the next firmware update
- vajimMaster
FURRYe38 wrote:Try the suggestion to see if it helps you out.
robertneaves wrote:Same problem!
