AngelicRocker's avatar
Dec 05, 2020
Drastically reduced internet speed at night (RBR50)
So I bought and installed my Orbi system in January 2020 and loved it immediately, solved nearly all of my household's internet issues at the time. Cut to September 2020 and we have a Spectrum technician out who is able to replace some interior cable and the PoE to solve our remaining issues entirely. Part of that September solution involved replacing the Spectrum-issued modem with a Netgear CM600, attached to the Orbi RBR50 router base.
This past week, however, internet speed has become drastically reduced in the evenings only. Our plan is 200mbps down, and at it's worst point this week we're getting speeds in the neighborhood of 1-5mbps down (our 10mbps upload has not been affected at all during this time).
I've gone through every configuration of testing I can think of swapping ethernet cables around, testing direct ethernet connection to the modem, etc, and in 3/4 tests, direct connection modem to PC works completely normally. Most tests using the Orbi again test normally for about 5 minutes after rebooting the modem, then return to the super slow speed.
I updated the Orbi firmware to v2.5.2.4 last night (via the app) thinking it may help, but it didn't.
I'm at a loss for ideas at this point and very much hoping someone here can help.
Thank you
    • AngelicRocker's avatar
      AngelicRocker
      Just did a 1 minute power off on the modem and router and manually updated the router to v2.7.1.60. Have not done another power cycle after update (only the reboot it did itself after installing) nor have I done a full factory reset (trying to avoid that if at all possible).
      Again after rebooting both the wired and wireless signals test properly though I'm expecting it to drop any minute.
      • FURRYe38's avatar
        Try the reset if it happens...
  • What's happening at night in your house?  More people online?  Streaming movies, gaming,etc ?
    Evenings are typical high use times across neighborhood connections
    slow down as In buffering?
    it's also possible someone has gained access to your network.  Change your password
      AngelicRocker
      As far as I can tell, nothing has changed. This problem only started 6 days ago and was never an issue before then. Nobody in the house is doing anything different than they are throughout the day either.
      Slow down as in my 200mbps ISP plan that normally reports anywhere from 180mbps to 250mbps on both wired and wifi connections drops and reports anywhere from 600kbps to 10mbps. Only starting around 5 or 6 PM and lasting usually all night with some pockets of full download speed splashed in.
      As far as someone gaining access to the network, the Orbi app isn't reporting any unknown devices connected.
      • FURRYe38's avatar
        Has the ISP modem or ONT been powered OFF for 30 seconds then back ON.
        Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
        Be sure there are no coax cable line splitters in the between the modem and ISP service box.
        Be sure your using good quality RG6 coax cable up to the modem.
        https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
        Could have yoru FW been updated 6 days ago if you recall?
