rix0rrr's avatar
Feb 12, 2018
Drops network every 30 seconds for 5 seconds
My Orbi is dropping network connectivity for 5 seconds just about every 30 seconds. It's not exactly 30 seconds, but it does occur very regularly, definitely every minute.
I'm on version 2.1.2.18. I unpowered the satellite to see if that was it, but that didn't help.
I captured ping statistics over a day (pinging a host on the same network over WiFi every second) so you can see the connectivity (timeout was set at 5 seconds, so all dropped connectivity shows as a latency peak to 5000 milliseconds).
How do I fix this? I thought this was supposed to be a good piece of kit.
Graph of my network interruptions over 1 day
  • Here's an interesting bit of info:
    I found somewhere on the forum that you can go to a special url, http://<ip-of-router>/debug.htm, and from there I found I can ENABLE TELNET ACCESS!
    After logging in on the box, I noticed a process called something like "miniupnpd" (or similar, it's hard to check now) eating a lot of CPU. After killing it, I still see occasional lag spikes of 100-200ms, but the drops are gone!
    • rix0rrr's avatar
      rix0rrr
      Star
      Okay so killing miniupnpd doesn't fix it. The hangups occasionally still happen, but less frequently (once every hour or so).
      Dropping packets/high latencies seem to be accompanied by high CPU usage on the Orbi.
      • webminster's avatar
        webminster
        Luminary
        Given your discovery, do you have UPnP enabled or disabled in the Web UI? Advanced Setup.  Causes issues for many people.
