Lethal57
Apr 07, 2019Guide
Extending coverage
Hi, I have placed my R6400V2 next to the ISP supplied modem/router, which wont cover more than 5 metres (poor tech choice by isp).
They seem to work ok together (bandwidth/frequency wise).
Wondering if the Netgear ac2200 (rbk30) would work with the R6400V2
Looking forward to further advises
Lethal
Lethal
So what you're trying to do is this?
ISP modem-->R6400v2-->RBK30
What I'd try to do is go:
ISP modem/router--->RBK30
See how that works. the RBK30 should cover around 3500 square ft if setup properly. How much area are you trying to cover? If it doesn't cover enough, you can add the r6400v2 back in. In my opinion, simpler is better as it reduces conflict or chances of failure.
If you get the Orbi set, I'd shut off the wireless on the isp supplied device unless you really need it.
If you have the R6400V2 sitting next to a modem/router that also delivers wifi, then you shouldn't need the wifi from the modem.router. Best turn it off.
If the R6400V2 doesn't cover five metres, then something is wrong.
You should not need anything else to go that far.
If you don't own the RBK30 already, before spending money on more equipment, I'd put a bit of effort into setting up what I already own.
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
That it the ISP's box supplies wifi suggests that it is a modem/router. Two routers on your network can cause headaches. This might screw up your existing wifi sources.
I think the OP is stating that the ISP's equipment won't cover more than 5 meters, not the R6400v2. I could be wrong though.
Who knows?
But plugging the R6400v2 into a modem/router means that they probably have two wifi sources sitting next to each other. Not a good idea.
- Lethal57Guide
Hi
Thanks muchly for your contribution/response. Indeed thank you all for your responses!
Just how would you "If you don't own the RBK30 already, before spending money on more equipment, I'd put a bit of effort into setting up what I already own.'???
The ISP Modem is a Sagemcom AC WiFi modem. If this helps...
I have had issues with it previously whilst a cable customer of the same isp, their NBN model is worse!
Secondly, the r6400v2 does not unfortuntely support VOIP...hence the need for the isp modem (which does).
Looking forward to your response
I don't understand. What's the question?
Like I said if you don't own the RBK30, spend some time setting up the R6400V2.
That is not much help. Sagemcom is a brand name. What is the model?
If it does wifi, then it is probably also a router. Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
Iy may be possible to put the modem/router into modem only (bridge) mode and then to use the R6400V2 as the router. But sometimes it is just easier to put the R6400V2 into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportUnfortunately, it still isn't clear to me what your problem is and what you are trying to do.
Might be helpful as well:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
