DAC128's avatar
DAC128
failure to connect orbi to satillite
Purchased new on 8/22/2018. Need phone number for support.
Orbi Router can't find satellite,
DAC128
  • FURRYe38's avatar
    What FW are you using on the router?
    Was the rourter FW updated before the satellite?
    Are you getting a pulsating WHITE led on top of the satellite after its ready?
    • DAC128's avatar
      DAC128
                  FW is 2.1.4.16
                   Router was not updated.
                    Satellite is pulsating WHITE.
                   Thanks for responding,  do you know of a Netgrear support phone number?
