bearyoung
Oct 25, 2019Aspirant
Firmware of europe
I bought a rbk23 in US, will move to Germany soon, can I use it's newst firmware of Europe? Will I brick the orbi?
FW is not region specific. You can select from the drop down box under the log out button on the RBRs web page to select a country listed i n the drop down.
bearyoung wrote:
I bought a rbk23 in US, will move to Germany soon, can I use it's newst firmware of Europe? Will I brick the orbi?- schumakuGuru - Experienced User
FURRYe38 wrote:FW is not region specific.
bearyoung wrote:
I bought a rbk23 in US, will move to Germany soon, can I use it's newst firmware of Europe? Will I brick the orbi?That's true. Cumbersome: There is (to my limited Obri-insight) no way top adjust the wireless legislation on the FCC (US) units - these are locked to US/FCC - so no way to operate legally under European (or other legislation - this is only possible on European [xxxxx-n00EUS] or Asia/pacific [xxxxx-n00PAS] models coming with the worldwide [WW] preset). Worse: Depending on the channels configured, region sensitive clients (like mobile phones) might fail to see any connect the wireless radios.
- bearyoungAspirantIs that possible to change the settings to WW via telnet? I saw someone has succesed on a rbk53.
FURRYe38 wrote:FW is not region specific. You can select from the drop down box under the log out button on the RBRs web page to select a country listed i n the drop down.
I may be mistaken, but I think the drop down menu under the Logout button is to select the language rather than the WiFi Region.
Yes, this was my intended understanding and responce. I should have included that as well.
Thanks.
- 3nwqAspirant
US is more restrictive on the 2.4GHz channels, not allowing the channels 12 and 13.
On 5 GHz your Orbi will default different channels that would be used in Europe.
But all those channels that are available in USA are ok to use in Europe.
So don't worry. Just use it.
I believe this is the post describing how to change the Region
https://community.netgear.com/t5/Orbi/ORBI-RBK53-Region-Change/m-p/1811833#M72806
- bearyoungAspirantMy concern is that I am not sure if this works on the rbk23, as you wrote, the method is for rbk53.
3nwq wrote:But all those channels that are available in USA are ok to use in Europe.
Afraid, this is not longer correct - it was upon a time. Channels 149..165 are no longer allowed to be used in Europe for WiFi - only max. 25 mW for SRD. And this is exactly where Orbi does prefer to run the wireless backhaul in the FCC version - that's why the impact on the client connections is limited.
