pettusta's avatar
pettusta
Follower
Feb 25, 2018
Firmware Upate 2.0.1.4
I’m currently on 2.1.2.18 on the RBR50/RBS50, and I see there is a firmware update on the support page showing version 2.0.1.4. That seems like it may be an older release, which makes me wonder if I should avoid installing it. Has anyone else installed it, or is this just for a specific issue?
1 Reply
  • Anonymous's avatar
    Anonymous
    They've stepped back.  2.0.1.4 is now considered the latest version.  If your system is running OK with what you have, best advice is leave it alone.
