jvmagic's avatar
jvmagic
Follower
May 01, 2020
Firmware update - msg - Looks like you’re not connected xxxx
Hi,
I have the latest 'Xfinity' box and upgraded to 1G speeds.  In my two story home I get 600-700 or os dowload speeds when I'm next to the router.  The Orbi satellite is downstairs and I cannot connect to the wifi (90 percent of the time).  No wifi connection which is weird because w/out the Orbi and just the Xfinity router, I can get better wifi connection.  I reset the Orbi satellite via the reset button and nothing has changed.
I was trying to update the firmware by following the orbi manual instructions but when I login to orbilogin.com it stating " Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps to get connected:"  No matter if I clear the browser cache etc.
So I have two problems:
Can't upgrade the firmware - current v2.3.5.26
Wifi not working on satellite - RBR20
Comcast router model - XB6-A
Thanks in advance
  • CrimpOn's avatar
    CrimpOn
    Would help to know how you are administering the Orbi system:
    • computer of some sort usiing a web browser, or
    • the Orbi "app"
    A lot of customers elect to disable the WiFi on their ISP modem/WiFi/router to reduce WiFi interference in the house.
    The specific firmware version is not likely to affect whether devices can connect to the Orbi WiFi or not.  There is likely something else to be addressed rather than the firmware level.
  • FURRYe38's avatar
    IF the ISP modem has a built in router already, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    You can get v16 FW from here if you want to manually download and install.
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
    Install the RBS first then RBR lastly.
    jvmagic wrote:
    Hi,
    Thanks in advance
