LifeAsCason's avatar
LifeAsCason
Firmware Update CBR40 2.3.5.30?
Each time I enter my Orbi app on my iPhone, I'm prompted with a message that shows that there is an update available. The app shows that my current firmware is "2.3.5.12" and the new update is "2.3.5.30". I tap update and it goes through the motions, "Rebooting Orbi" & then waiting for it to come back online and say the update was successful, however the Orbi never rebooted. I've gone onto OrbiLogin.com to manually update the firmware, but the firmware check says that "2.3.5.12" is the most current version of CBR40's firmware available. I've gone to Netgear downloads to see if I could download "2.3.5.30" but that firmware does not exist from CBR40, the most recent release on Netgear Downloads is, "2.3.5.12".
Any idea's on why this is happening? Is there actually an update? Is it a problem with the Orbi app? Maybe displaying a yet to be released update?
P.S. Both of my satellites are also on the most current version of their respective firmware software as well.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi LifeAsCason
    Welcome to NETGEAR Community!
    The latest CBR40 firmware is v2.3.5.12.
    The latest RBS50 firmware is v2.3.5.30.
    You mentioned that both of the satellites are on the most current version, may I please know the firmware version just to check?
    Blanca
    Community Team
    • LifeAsCason's avatar
      LifeAsCason
      Blanca_O
      Here is a screenshot of all of the firmware on my system.
      I can see the firmware you mentioned “ v2.3.5.30” in the NETGEAR downloads page for the RBS50 but is it not an older version that the “V2.5.1.8”? It says no new firmware for any of my devices so I’m confused.
      • FURRYe38's avatar
        Use a web browser and manually download the FW files from NG support site for the RBS and CBR. Apply the FW files manually using the web browser connected to the RBS first, then the CBR lastly. I would factory reset both and then setup from scratch.
        LifeAsCason wrote:
        Blanca_O
    • DocJim's avatar
      DocJim
      I believe that for CBR 40 you are correct that the current firmware is V2.3.5.12
      I have RBS20 satellites (I don't know about RBS50) and their current firmware is V2.3.5.30
      I think that the issue we are having is with the App telling us that the firmware needs updating, and is seeing the CBR40 firmware (which is current) and looking at the update for the RBS20 and since the CBR isn't V2.3.5.30 saying it is out of date  . . . which it is not.
      Make sense.  It's an APP problem.
      • FURRYe38's avatar
        One can manually update the RBS to v16 and then check the app again. Ya, seems that the app maybe incorrect.
