rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4 and IPv6 - much happiness in my household. =)
Rodney
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
- ScreamzGuide
I believe I have found my iPhone issue out. With the new firmware you can see what devices are connected to 2.4g and 5g networks. While I'm inside the house iPhones are running nicely on the 5g network. Soon as I step outside in the backyard they get pushed to the 2.4g network, and the disconnects and the extremely slow speeds kick in. I wish there was a way to disable 2.4g on the iPhone.
- Dustin278ApprenticeA couple things that I would try would be turned down 2.4 transmission to like 50%or try a different Channel on your 2.4 and you something like 1 or 6 or 13
- DarrellRiffeApprentice
I've temporarily resolved my dropout problem by simply turning off both satellites. Stable, but I don't get the coverage that I need in my house. When I first installed the RBK53, it was fantastic. Two firmware updates later (including the beta), and I basically have three expensive paperweights. So tomorrow, I'm getting a new router. I haven't yet decided which one, but I'm researching tonight. I do know that it will not have the Netgear brand on it.
Adios!
- Dudes, the beta firmware absolutely fixed everything for my system. iPhones, Nvidia shield, laptops, Google pixel, Ethernet all works no one drop for a week +. One guy in a previous post linked the post that had the beta firmware. Get it from there if you don't want to wait until the next update. I can tell u that I won't change the beta even with future updates. Do a clean install. Best luck. Orbi when working is by far the best out there and I tried the eero 2nd gen pro.
- ArtLeeApprentice
Pichontech wrote:
Dudes, the beta firmware absolutely fixed everything for my system. iPhones, Nvidia shield, laptops, Google pixel, Ethernet all works no one drop for a week +. One guy in a previous post linked the post that had the beta firmware. Get it from there if you don't want to wait until the next update. I can tell u that I won't change the beta even with future updates. Do a clean install. Best luck. Orbi when working is by far the best out there and I tried the eero 2nd gen pro.Of course, your mileage may vary. I've been using current 1.12 firmware for a couple of months without any issues. What seems to work for one person here doesn't always work for all.
- ArtLeeApprentice
Pichontech wrote:
Dudes, the beta firmware absolutely fixed everything for my system. iPhones, Nvidia shield, laptops, Google pixel, Ethernet all works no one drop for a week +. One guy in a previous post linked the post that had the beta firmware. Get it from there if you don't want to wait until the next update. I can tell u that I won't change the beta even with future updates. Do a clean install. Best luck. Orbi when working is by far the best out there and I tried the eero 2nd gen pro.I had linked the Beta but I believe one of the MODs deleted the link. Yes mine has been flawless with the Beta for over a week.
- scornwellApprentice
Dustin278 wrote:
Try rebooting your router and see if it's still flawless.
- RogerSCVirtuoso
Hmmm...Checked for new firmware, found it and flashed it. As a result, Orbi router and satellite have just been updated to v2.0.0.72...assume that this is the next official release after v1.12.
Doing fine so far, but hasn't been very long yet. Expecting it to be fine, since v2.0.0.64 was doing fine as well.
Time will tell *smile*. Just found this:
https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
- tpgallGuide
Nice try guys but a fail. I upgraded to version 2 and within 2 hours everything was locked up. No internet access or WiFi access. Same as the previous versions. Until you perfect the firmware, the system is garbage. I have an expensive 6 month old paper weight. Not a complex network. One satellite and 22 devices connected to a Spectrum cable network thru a SB3400 modem.
It is obvious you have no clue as to what is wrong with these units. They should be recalled.
I am going to post to Amazon and other boards the truth about Orbi.
- spinkickApprentice
Its perplexing how some people have 0 problems and others have total trainwrecks. There has to be something causing this. My system is flawless, and I feel for you guys with issues.
