GloryUprising
Dec 11, 2017Aspirant
Google Home and Chromecast
So I got the super orbi crashing and rebooting on the router and satellites.
I seemed to have narrowed it down to when working with Google Home. When ever I try to stream something it would prompt an orbi reboot and I would loose wifi for 1-2 min while it boots back up. Sometimes, after the reboot, google home will work fine other times I'll get the message "hmm.. something is wrong try again in a few seconds" which usually prompts me to restart the home itself via unplugging.
Just recently (after upgrade to 2.0.0.74) I also noticed that my dropcams have been randomly dissconnecting. That prompted me to check [ipaddress]/debug.htm and I noticed that all my routers and satellites have been randomly restarting (via the uptime counter).
Upgrading to 2.1.1.12 still results in crashs and I also notice that I also have the CPU utilization 70%+ as well.
Halp?
- DarrenMSr. NETGEAR Moderator
Hello GloryUprising
Have you tried a factory reset of orbi since updating the firmware?
DarrenM
- GloryUprisingAspirant
Yes.
Factory restarted via webinterface and pin hole in back.
Also telneted and cleared NVRAM as well.
Still rebooting.
I suggest you contact support and work with them on the orbi rebooting issues they will be able to replace the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
